- What’s your URL? missionvictoryindia.com
- What version of Ghost are you using? 3.37.1
And
How was Ghost installed and configured? Ghost version: 3.37.1
OS: Ubuntu, v18.04.4 LTS
Environment: production -
[2020-11-07 20:26:07] INFO Creating database backup
[2020-11-07 20:26:08] INFO Database backup written to: /var/www/ghost/content/data/mission-victory-india.ghost.2020-11-07-20-26-07.json
[2020-11-07 20:26:08] WARN Skipping ON DELETE CASCADE for “members_labels_member_id_foreign” constraint - already set
[2020-11-07 20:26:08] WARN Skipping ON DELETE CASCADE for “members_labels_label_id_foreign” constraint - already set
[2020-11-07 20:26:08] WARN Skipping “members_stripe_customers_member_id_foreign” foreign key constraint creation - already exists
[2020-11-07 20:26:08] INFO Adding “members_stripe_customers_customer_id_unique” index
[2020-11-07 20:26:08] ERROR
MESSAGE: Cannot remove permission(Delete snippets) from role(Editor) - permission does not exist
level: normal
“OuterError: Field length of customer_id in members_stripe_customers is too long!”
RollbackError: Cannot remove permission(Delete snippets) from role(Editor) - permission does not exist
at RollbackError.KnexMigrateError (/var/www/ghost/versions/3.37.1/node_modules/knex-migrator/lib/errors.js:7:26)
at new RollbackError (/var/www/ghost/versions/3.37.1/node_modules/knex-migrator/lib/errors.js:31:26)
at /var/www/ghost/versions/3.37.1/node_modules/knex-migrator/lib/index.js:440:23
at tryCatcher (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/promise.js:547:31)
at Promise._settlePromise (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/promise.js:604:18)
at Promise._settlePromise0 (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/promise.js:649:10)
at Promise._settlePromises (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/promise.js:725:18)
at _drainQueueStep (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/async.js:93:12)
at _drainQueue (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/async.js:86:9)
at Async._drainQueues (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/async.js:102:5)
at Immediate.Async.drainQueues [as _onImmediate] (/var/www/ghost/versions/3.37.1/node_modules/bluebird/js/release/async.js:15:14)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
at down (/var/www/ghost/versions/3.37.1/core/server/data/migrations/utils.js:151:23)
[2020-11-07 20:26:12] INFO Blog is in maintenance mode.
[2020-11-07 20:26:12] INFO Ghost is running in production…
[2020-11-07 20:26:12] INFO Your site is now available on https://missionvictoryindia.com/
[2020-11-07 20:26:12] INFO Ctrl+C to shut down
[2020-11-07 20:26:12] INFO Ghost boot 3.317s
[2020-11-07 20:26:12] INFO Creating database backup
I simply ran the update after running the ghost doctor command.
I checked the database field and the database is empty and the field is already 255 varchar which more than 191 as suggested by another post on this forum.
Any help to restore our website other than setting it up again would be really appreciated!
