I just setup up Ghost on an ubuntu server on AWS EC2.
I’ve just tried uploading my own theme( passes gscan ) but I get an error
“Unexpected field”
And this error message in console
"errors": [
"message": "Resource not found",
"context": null,
"type": "NotFoundError",
"details": null,
"property": null,
"help": null,
"code": null,
"id": "cfa5e280-3a84-11e9-841d-4f3bbe0eacd0"
Ghost Log
[2019-02-27 11:49:05] ERROR "POST /ghost/api/v2/admin/themes/upload/" 500 44ms
CODE: LIMIT_UNEXPECTED_FILE
MESSAGE: Unexpected field
level: normal
InternalServerError: Unexpected field
at new GhostError (/var/www/ghost/versions/2.16.1/core/server/lib/common/errors.js:10:26)
at _private.prepareError (/var/www/ghost/versions/2.16.1/core/server/web/shared/middlewares/error-handler.js:43:19)
at Layer.handle_error (/var/www/ghost/versions/2.16.1/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/var/www/ghost/versions/2.16.1/node_modules/express/lib/router/index.js:315:13)
at /var/www/ghost/versions/2.16.1/node_modules/express/lib/router/index.js:284:7
at Function.process_params (/var/www/ghost/versions/2.16.1/node_modules/express/lib/router/index.js:335:12)
at next (/var/www/ghost/versions/2.16.1/node_modules/express/lib/router/index.js:275:10)
at Layer.handle_error (/var/www/ghost/versions/2.16.1/node_modules/express/lib/router/layer.js:67:12)
at /var/www/ghost/versions/2.16.1/node_modules/express/lib/router/index.js:635:15
at next (/var/www/ghost/versions/2.16.1/node_modules/express/lib/router/index.js:260:14)
at next (/var/www/ghost/versions/2.16.1/node_modules/express/lib/router/route.js:127:14)
MulterError: Unexpected field
at wrappedFileFilter (/var/www/ghost/versions/2.16.1/node_modules/multer/index.js:40:19)
at Busboy.<anonymous> (/var/www/ghost/versions/2.16.1/node_modules/multer/lib/make-middleware.js:114:7)
at emitMany (events.js:147:13)
at Busboy.emit (events.js:224:7)
at Busboy.emit (/var/www/ghost/versions/2.16.1/node_modules/busboy/lib/main.js:38:33)
at PartStream.<anonymous> (/var/www/ghost/versions/2.16.1/node_modules/busboy/lib/types/multipart.js:213:13)
at emitOne (events.js:116:13)
at PartStream.emit (events.js:211:7)
at HeaderParser.<anonymous> (/var/www/ghost/versions/2.16.1/node_modules/dicer/lib/Dicer.js:51:16)
at HeaderParser.emit (events.js:211:7)
at HeaderParser._finish (/var/www/ghost/versions/2.16.1/node_modules/dicer/lib/HeaderParser.js:68:8)
at SBMH.<anonymous> (/var/www/ghost/versions/2.16.1/node_modules/dicer/lib/HeaderParser.js:40:12)
at SBMH.emit (events.js:224:7)
at SBMH._sbmh_feed (/var/www/ghost/versions/2.16.1/node_modules/streamsearch/lib/sbmh.js:159:14)
Ghost-CLI version: 1.9.9
Ghost version: 2.16.1 (at /var/www/ghost)
Hope you can help
