'Name is not defined' error when uploading theme
I’m running into a weird error when uploading a custom theme to Ghost. I’ve been uploading iterations of the same theme file for the last couple weeks without issue, but today I’m getting this error:
Searched the forum but didn’t see a similar issue. What’s strange is that I’m getting the error for any theme I try to upload. Even getting the error when I download the current theme and re-upload it. Not sure what’s going on here.
  • What’s your URL? http://altpath.co
  • What version of Ghost are you using? Latest, hosted w/ Ghost Pro
  • Browser Latest version of Chrome OS Version 91.0.4472.114
Console Errors:
DevTools failed to load source map: Could not load content for https://altpath.ghost.io/ghost/assets/vendor.min-c93f83ffbab76cb5d00b091e7aef9452.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://altpath.ghost.io/ghost/assets/ghost.min-421ffe52eb692e5d473df86d435b0a91.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
Thanks in advance! :pray:
I am getting something similar when I try to upload changes to my theme this morning: ‘Cannot destructure property ‘theme’ of ‘undefined’ as it is undefined.’
Can you try upgrading to the latest (4.9.3 which was just released) version and seeing if the error persists?
If it does, can you share the relevant output of ghost log -e?
Sure. I’m hosted on Ghost Pro and not seeing the option to upgrade. Where can I find that in my account? @vikaspotluri123
Edit:
I opted to go with Ghost Pro as I’m not a super-technical user. Since I’m hosted w/ Ghost, I thought updates were automatic? ie. I’m not operating a self-hosted install, so I’m not really sure how to force the update. Any insights you can give would be greatly appreciated. :pray:
I’m in the same boat. Guess we just wait?
If you’re having any issue with a Ghost(Pro) site, please drop them an email on support@ghost.org and they’ll be more than happy to give you a hand directly :slight_smile:
Updates are automatic, but I’m not sure what the delay is between a release on GitHub and availability for you :smiley:
Done! I’ll update here when I get an answer.
Same thing here. Mysteriously started yesterday as I was updating my new theme. Never seen this error before. I deleted the theme. Got a fresh copy from the developer, made the necessary changes, re-uploaded and it worked. However, today after making many changes, it has happened again. I am on Pro and running 4.9.3.
Can you run your theme through https://gscan.ghost.org (you can also use the gscan cli if you’re privacy conscious :slight_smile:)? The name is not defined error is a bug in Ghost, but it only shows up if your theme might be invalid
Thank you @vikaspotluri123 I will go try that now. FYI I have just discovered that if I remove my custom home.hbs and compress to a zip file, the theme is accepted by the ghost admin. If I put the custom home.hbs file back, it throws the error.
I ran both zips through the scan. Both validated 100%. But the one that contained the home.hbs noted a handlebar error. Will investigate and fix.
A missing leading { in one of the handlebars. I zoomed up the Coda editor and saw it right away. I need new glasses. Thank you @vikaspotluri123 for letting me know about the gscan tool. Will use this always now. Hopefully @justinv will find a similar solution.
