Based on what I read here, installing the plugin and setting it in the gatsby-config.js file is simple.
But now how do I use it with Ghost?
You would need to use the source plugin for Ghost: gatsby-source-ghost | Gatsby
This way you are able to fetch the data from your Ghost installation.
You can see the source plugin in action with our Gatsby Starter: GitHub - TryGhost/gatsby-starter-ghost: A starter template to build lightning fast websites with Ghost & Gatsby
Do you mean that I don’t have to use the gatsby-source-iubenda
but i have to fetch the data directly from my main installation?
It is not very clear to me looking at ghost-starter.
is it possible a small example on how to fetch my data of iubenda to visualize them with gatsby?
