Get post excerpt without stripping HTML?
Is there a way to grab a post’s excerpt without stripping the html?
I know the data helper {{excerpt}} is the typical way, but this strips HTML by default.
I wonder if it would be better if you used the post code injection area and repurposed it for the excerpt :thinking:. That would definitely not strip the HTML
Ooh yes, thank you, I’ll give that a try!
Didn’t realize this was a thing > Post Code Injection
