Hi Team,
I had installed ghost from google one-click deploy and the version of Ghost 1.21.4 and Ghost CLI (1.4.2) after that I had done ghost-google-cloud-storage W.R.T this URL ghost-google-cloud-storage - npm after that I had imported our old posts from bitnami
ghost and the version of Ghost 1.22.1 and Ghost CLI (1.6.0)
Getting 500 error after importing my old posts
Error log:
[2018-04-25 13:34:26] ERROR “GET /” 500 60022ms
MESSAGE: [default.hbs] name.replace is not a function
level: normal
InternalServerError: [default.hbs] name.replace is not a function
at new GhostError (/var/www/ghost/versions/1.22.1/core/server/lib/common/errors.js:9:26)
at prepareError (/var/www/ghost/versions/1.22.1/core/server/web/middleware/error-handler.js:39:19)
at Layer.handle_error (/var/www/ghost/versions/1.22.1/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/var/www/ghost/versions/1.22.1/node_modules/express/lib/router/index.js:315:13)
at /var/www/ghost/versions/1.22.1/node_modules/express/lib/router/index.js:284:7
at Function.process_params (/var/www/ghost/versions/1.22.1/node_modules/express/lib/router/index.js:335:12)
at next (/var/www/ghost/versions/1.22.1/node_modules/express/lib/router/index.js:275:10)
at Layer.handle_error (/var/www/ghost/versions/1.22.1/node_modules/express/lib/router/layer.js:67:12)
at /var/www/ghost/versions/1.22.1/node_modules/express/lib/router/index.js:635:15
at next (/var/www/ghost/versions/1.22.1/node_modules/express/lib/router/index.js:260:14)
at Immediate.next (/var/www/ghost/versions/1.22.1/node_modules/express/lib/router/index.js:260:14)
at Immediate. (/var/www/ghost/versions/1.22.1/node_modules/express/lib/router/index.js:635:15)
