if i import on my local ghost serve with the same file then it working fine but on my domain it says Path must be a string. Received undefined when i import from a json file
please help…!!!
please help…!!!
I’m having the same issue trying to import to a GhostPro install. This worked just last week, so I’m guessing it’s a bug in the latest release? I’ve sent an email to support about it as well. Here’s hoping!
yeah got it… resolved … thanks man … on 2.8.0 is worked fine. @icaspar
Hi @Shubham_Verma! The new version - 2.9.1, was just released with a fix to the import issue. So, everything should work once you upgrade to the latest
