Ghost 2.16 broken URLs in post-card
After upgrading to Ghost 2.16.1 post-cards under the post (I’m using default Casper theme) are targeting to / instead of post URL.
Take a look at the post at https://blog.bounz.net/agentika/. In “read next” blog post-cards for other posts are targeting to /:
The same page’s post-card when running Ghost 2.15 has the correct URL pointing to /nikogda-nibud/:
I’m running Ghost using Docker with this command:
docker run -d --name ghost1 -p 22368:2368 -e url=https://blog.bounz.net -v ~/ghost1:/var/lib/ghost/content ghost:2.16
Everything works well if I run
docker run -d --name ghost1 -p 22368:2368 -e url=https://blog.bounz.net -v ~/ghost1:/var/lib/ghost/content ghost:2.15
It seems that {{url}} helper outputs strange URL for post context.
Was already fixed and released asap :slight_smile:
:tada: Thanks!
Look forward to the new Docker image!
2.16.3 was released.
I faced this issue also … just upgrade ghost using cli type
ghost upgrade
and you are done !
