Issue #1
When users with “Contributor” role try to write a post using the Ghost mobile app, it doesn’t sync to the server.
I was going through a debugging session and found the following error when a contributor tries to create a post.
{“errors”:[{“message”:“You do not have permission to add posts”,“errorType”:“NoPermissionError”}]}
Issue #2
When this happens, Ghost mobile app keeps trying to sync with the server and finally it goes through the spam prevention system resulting in the following error
{“errors”:[{“message”:“Too many attempts try again in an hour”,“context”:“Only 100 tries per IP address every 3600 seconds.”,“errorType”:“TooManyRequestsError”}]}
Then no one in the same network can even log in to the app within an hour.
Does anyone have any idea how to fix this?
Thanks,
Kasun.
