Ghost-cli backup command generates error
Issue Summary
ghost backup command run from ghost-cli fails.
  • Explain roughly what’s wrong
  • When I run the ghost backup command from the ghost-cli, Backing up site fails with message A ProcessError occurred.
  • What did you expect to happen?
  • I expected a successful backup to be generated.
Steps to Reproduce
  1. Log in to server
  2. Switch user to ghost-mgr. sudo -i -u ghost-mgr
  3. Change directory to ghost. cd /var/www/ghost
  4. Run ghost backup command.
Setup information
Ghost Version
Ghost Version: 5.95.0
Ghost-CLI Version: 1.26.1
Node.js Version
v18.20.4
How did you install Ghost?
Digital Ocean marketplace - Ghost
Ubuntu, v22.04.5 LTS
Database type
mysql 8.0.39-0ubuntu0.22.04.1
Browser & OS version
Include if reporting frontend bugs.
Relevant log / error output
ghost-mgr@ourtwocentstravel:/var/www/ghost$ ghost backup
https://careers.ghost.org
+ sudo systemctl is-active ghost_ourtwocentstravel-com
+ sudo mkdir -p /var/www/ghost/backup
? Enter your Ghost administrator email address ted.leroy@protonmail.com
? Enter your Ghost administrator password [hidden]
+ sudo cp /var/www/ghost/backup/content-from-v5.95.0-on-2024-10-04-14-20-57.json /var/www/ghost/content/data/content-from-v5.95.0-on-2024-10-04-14-20-57.json
+ sudo cp /var/www/ghost/backup/members-from-v5.95.0-on-2024-10-04-14-20-57.csv /var/www/ghost/content/data/members-from-v5.95.0-on-2024-10-04-14-20-57.csv
+ sudo chown -R ghost:ghost /var/www/ghost/content
✖ Backing up site
Message: EACCES: permission denied, open '/var/www/ghost/content/data/content-from-v5.95.0-on-2024-10-04-14-20-57.json'
Exit code: EACCES
Shouldn’t the chown command be to ghost-mgr:ghost-mgr, not ghost:ghost?
sudo chown -R ghost:ghost /var/www/ghost/content should be
sudo chown -R ghost-mgr:ghost-mgr /var/www/ghost/content shouldn’t it?
Check your permissions and ownership. The content folder is owned by ghost.
Thank you mjw,
I think the permission denied error is due to the script doing sudo chown -R ghost:ghost /var/www/ghost/content instead of sudo chown -R ghost-mgr:ghost-mgr /var/www/ghost/content, is it not? This is why I’m submitting as a bug. I’m running the command as ghost-mgr, not as ghost. I’m wondering if the script hasn’t been updated to reflect use of ghost-mgr?
Sorry, mjw,
Are you saying the content folder is supposed to be owned by ghost, not ghost-mgr?
Kind regards,
Ted
I ran ghost doctor and corrected permissions as it recommended, then re-ran ghost backup and it ran clean. Thanks mjw!
Yes, ghost-mgr could be any user with permission to install and maintain Ghost. ghost owns content, and should not be confused with ghost-mgr.
Thanks so much for your help mjw!
I really try not to post stupid mistakes I make as bugs. Obviously I’m not always successful.
Sorry to have wasted your time on a silly mistake on my end.
Kind regards,
Ted
