Hi, firstly I hope everyone is well and safe at this difficult time. Per the title, I’ve upgraded my Ghost installation from v1 to v3. (details below) and Ghost is failing to start.
Symptoms:
ghost start or ghost restart hangs
ghost run shows a connection refused on bootstrap port 8000
- if I go to config.json and remove the bootstrap-socket stanza, then run
ghost run, ghost starts OK (but obviously that’s not ideal)
- if I then run
ghost start or ghost restart, the bootstrap stanza is reinserted and ghost fails to start
netstat indicates nothing else running on 8000; and if I change the bootstrap port to another number I still get the same issue
Version info:
- OS = Ubuntu 18.04.4 (Digital Ocean droplet)
- Nginx = 1.14.0
- Node = 10.19.0
- Ghost-CLI = 1.13.1
- Ghost = 3.12.1
Here’s the config file (bootstrap-socket stanza included). The port 2368 correctly maps to the nginx config and, per the above, ghost does indeed start if it doesn’t have to connect to the bootstrap port:
"url": "http://www.mydomain.net",
"server": {
"port": 2368,
"host": "127.0.0.1"
"database": {
"client": "mysql",
"connection": {
"host": "localhost",
"user": "ghost",
"password": "longstring",
"database": "ghost"
"mail": {
"transport": "Direct",
"options": {
"service": "Mailgun",
"auth": {
"user": "postmaster@sandboxlongstring.mailgun.org",
"pass": "longstring"
"logging": {
"transports": [
"file",
"stdout"
"process": "systemd",
"paths": {
"contentPath": "/var/www/ghost/content"
"bootstrap-socket": {
"port": 8000,
"host": "localhost"
Would very much appreciate any ideas, thanks.
Also, noticed this in repeatedly syslog, if relevant. The error appears if I run ghost start but not if I use ghost run.
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: /var/www/ghost/versions/3.12.1/node_modules/fs-extra/lib/index.js:5
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: ...require('./fs'),
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: ^^^
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: SyntaxError: Unexpected token ...
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at Object.exports.runInThisContext (vm.js:76:16)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at Module._compile (module.js:542:28)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at Object.Module._extensions..js (module.js:579:10)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at Module.load (module.js:487:32)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at tryModuleLoad (module.js:446:12)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at Function.Module._load (module.js:438:3)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at Module.require (module.js:497:17)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at require (internal/module.js:20:19)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at Object.<anonymous> (/var/www/ghost/versions/3.12.1/core/server/config/utils.js:2:10)
Mar 28 22:15:40 ghost-1gb-lon1-01 node[16149]: at Module._compile (module.js:570:32)
Mar 28 22:15:40 ghost-1gb-lon1-01 systemd[1]: ghost_www-conqueredworlds-net.service: Service hold-off time over, scheduling restart.
Mar 28 22:15:40 ghost-1gb-lon1-01 systemd[1]: ghost_www-conqueredworlds-net.service: Scheduled restart job, restart counter is at 3.
Does ghost doctor run clean?
Yes
gam@ghost-1gb-lon1-01:/var/www/ghost$ ghost doctor
✔ Checking logged in user
✔ Checking operating system compatibility
+ sudo systemctl is-active ghost_www-conqueredworlds-net
? Sudo Password [hidden]
+ sudo systemctl reset-failed ghost_www-conqueredworlds-net
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
Are you running nvm on your server? This might be why it’s unable to run Ghost, as Ghost may be using an older, or newer, version of Node. We recommend uninstalling nvm for production sites Using nvm with local and production Ghost installs and installing the right version globally How to install & setup Ghost on Ubuntu 16.04, 18.04, 20.04 or 22.04
Hope this helps!
David
Thanks for your help, this basically fixed it.
- Removed local copies of node and nvm per the instructions.
- Discovered rogue copy of ghost-cli in /usr/local/bin; removed that
- For some reason my ghost user doesn’t pick up /usr/bin, symlinked ghost and node to /usr/local/bin
System now starts fine.
Many thanks
Mark
Also removed a bunch of other stuff from /usr/local/bin but for some reason it still insists on the node and ghost executables being there to start.
