I have been trying to setup ghost locally following all the steps from the documentation and it always shows this on my terminal:
$ docker-compose -f .github/scripts/docker-compose.yml down -v && docker-compose -f .github/scripts/docker-compose.yml up -d --wait
ERROR: The Compose file './.github/scripts/docker-compose.yml' is invalid because:
'name' does not match any of the regexes: '^x-'
You might be seeing this error because you're using the wrong Compose file version. Either specify a supported version (e.g "2.2" or "3.3") and place your service definitions under the `services` key, or omit the `version` key and place your service definitions at the root of the file to use version 1.
For more on the Compose file format versions, see https://docs.docker.com/compose/compose-file/
error Command failed with exit code 1.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
Failed to run MySQL Docker container Error: 'yarn docker:reset' exited with code 1
at ChildProcess.<anonymous> (/home/azeez/Ghost/.github/scripts/setup.js:26:24)
at ChildProcess.emit (node:events:513:28)
at maybeClose (node:internal/child_process:1091:16)
at ChildProcess._handle.onexit (node:internal/child_process:302:5)
Hint: is Docker installed and running?
Running knex-migrator init
warning ghost@5.81.1: The engine "cli" appears to be invalid.
$ /home/azeez/Ghost/node_modules/.bin/knex-migrator init
[2024-04-03 23:29:10] ERROR Cannot find module '/home/azeez/Ghost/node_modules/@tryghost/post-revisions/build/index.js'. Please verify that the package.json has a valid "main" entry
"OuterError: Cannot find module '/home/azeez/Ghost/node_modules/@tryghost/post-revisions/build/index.js'. Please verify that the package.json has a valid \"main\" entry"
Error ID:
400
Error Code:
MODULE_NOT_FOUND
Error: Cannot find module '/home/azeez/Ghost/node_modules/@tryghost/post-revisions/build/index.js'. Please verify that the package.json has a valid "main" entry
at /home/azeez/Ghost/node_modules/knex-migrator/lib/index.js:240:23
at tryPackage (node:internal/modules/cjs/loader:400:19)
at Module._findPath (node:internal/modules/cjs/loader:613:18)
at Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
at Module._load (node:internal/modules/cjs/loader:841:27)
at Module.require (node:internal/modules/cjs/loader:1061:19)
at require (node:internal/modules/cjs/helpers:103:18)
at Object.<anonymous> (/home/azeez/Ghost/ghost/core/core/server/models/post.js:21:25)
at Module._compile (node:internal/modules/cjs/loader:1159:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1213:10)
at Module.load (node:internal/modules/cjs/loader:1037:32)
at Module._load (node:internal/modules/cjs/loader:878:12)
at /home/azeez/Ghost/ghost/core/core/server/models/index.js:26:27
at Array.forEach (<anonymous>)
at Object.init (/home/azeez/Ghost/ghost/core/core/server/models/index.js:23:17)
reject(new Error(`'${command} ${args.join(' ')}' exited with code ${code}`));
Error: 'yarn knex-migrator init' exited with code 1
Node.js v18.12.1
I have docker installed and docker-compose. I don’t know where the error is coming from. Please help
Thank you!
