Ghost is apparently not reading environment variables (using Docker)
Hello. Thank you for the amazing piece of software and tooling :slight_smile:
We have a Ghost instance running on Digital Ocean. We are starting it with Docker/Podman. The environment variables seem to be passed to the container, but not read by Ghost itself.
For example, running env inside the running container prints:
mail__transport=SMTP
GHOST_VERSION=5.121.0
because we have the following docker-compose.yaml
ghost:
    container_name: ghost
    image: ghost:latest
    restart: always
    environment:
      url: https://${GHOST_DOMAIN}
      mail__transport: SMTP
However, running ghost config mail.transport prints
https://careers.ghost.org
Direct
Because of this, we cannot send transactional emails, and thus I cannot login (due to the new feature of demanding that staff users get an email when logging in).
Are we doing something wrong? Thanks!
As far as I understand, ghost config [key] does not return environment variables. Just tried it on a running site that definitely has stuff set (e.g. url) and I am getting the same result as you.
So, the issue is rather with the mail setup itself. The fact that ghost config [key] does not return anything is a red herring.
How does the rest of the mail configuration look like? Has this worked before?
As an alternative, if you need to log in quickly, have a look here at the security config:
Hello Jannis. That helps definitely.
I have disabled that and logged in successfuly :slight_smile:
It has worked in the past.
The rest looks like this:
mail__options__secure=True
mail__options__auth__user=geral@d**o.pt
mail__options__port=465
mail__from='***' <geral@d**o.pt>
mail__options__auth__pass=***
mail__options__host=mail.d**o.pt
With “***” being just redacted stuff, that should be correct. We have also tried using Mailgun, with no success. We will try again later, but it should be working, I think.
Glad to hear it’s working!
In production, the mail setup is required (meaning, if new features are added, Ghost assumes that you have a working mail setup for production), so you should figure that out.
What I’d check is if the exact SMTP credentials work elsewhere. Then work from there.
Bingo. That’s your problem. DO is blocking outbound SMTP. Switch to port 2525 (not blocked by DO recently at least), or switch to using a mail service that’ll accept email via API.
Not having to deal with DO myself, I always forget about that. Good point! :upside_down_face:
I don’t use DO either, I’ve just seen it enough times!
