Ghost locks up when deleting a post
I’ve experienced this twice now. After I confirm that I want to delete, things just lock up. The only way to fix it is to delete everything in the browser address bar, except relief-mine.ghost.io, and then reload the page.
Known issue?
Happens to me, too.
You can instead right click from the list of posts and delete it there, but that misses the opportunity to be extra triple sure that you’re deleting the right one…
I assume this is on the known bug list and that the Ghost team will have it fixed in the next release, right?
Cathy, do you have a webpage that describes your theme modification services?
Thanks for reporting this. Our engineers are currently investigating, and I’ll post any updates here.
Also, from my initial investigation, it seems like this only affects imported posts. Is that right?
Again, thanks for reporting this @Cathy_Sarisky @spendlove!
Our engineers have identified the bug and deployed a fix. It should already be rolled out to Ghost(Pro) users, and the fix will be included in tomorrow’s release.
Good work guys! Thank you.
Huzzah. Kudos go to @spendlove . I’d been ignoring it as a nuisance (and assumed someone had a bug filed on it), so I’m glad he reported it!
