Ghost Starter Theme + fslightbox
Hi!
I started a new theme with the Ghost Starter Theme and want to add fslightbox.
I have found the follwing post https://brightthemes.com/blog/ghost-image-lightbox
I am using Visual Studio Code and “compile” the theme ZIP with npm build / zip.
I am trying to do it via “Install via npm & gulp”… to include it directly in the theme.
Have I to add gulp to do it? And if so: how?
Thanks for your help!
Martin
If you use the ghost default theme Source there a lightbox integrated.
Otherwise use the section “Install directly” in the the link from above: https://brightthemes.com/blog/ghost-image-lightbox
It’s very easy to implement and it works perfect.
