Ghost x Zapier - error message (2)
Trying to follow up on Ghost x Zapier - error message
When trying to connect from Zapier, I get the following error message:
authentication failed: request to https://<example.com>/ghost/api/v0.1/authentication/token failed, reason: connect ECONNREFUSED X.X.X.X:443
At the same time with ghost log -f, I get:
[2018-07-07 04:26:03] INFO “GET /ghost/api/v0.1/configuration/” 200 4ms
[2018-07-07 04:26:03] INFO “GET /ghost/api/v0.1/configuration/” 200 5ms
…and in /var/log/nginx/access.log:
18.207.163.130 - - [07/Jul/2018:04:26:03 +0000] “GET /ghost/api/v0.1/configuration/ HTTP/1.1” 200 176 “-” “Zapier”
Any idea on how to attempt to debug this further?
nginx has proxy_pass http://127.0.0.1:2368; without any HTTP verb limits.
Just tried signing in to the ghost admin, ghost log showed:
[2018-07-07 04:43:03] INFO “POST /ghost/api/v0.1/authentication/token” 200 266ms
It looks like ghost and the server are set up correctly (?), but for some reason Zapier cannot connect.
