Hi everyone. I’m needing some quick advice.
I have my small business website on Squarespace (https://www.teachmindset.com) - I’m happy with home page / about etc but my BLOG needs a lot of work and Squarespace templates so limiting. Ideally, I want my blog on ghost - on a subdomain. If I did this would it hurt SEO? I really want to start writing and publishing more prolifically.
Also - is there any easy way I can replicate the current site structure and have a great blog all on GHOST?
Any advice welcome please about which way makes sense.
Thank you!
It wont hurt the seo… You can use a permanent redirection from yourdomain.com is available for purchase - Sedo.com to blog.yourdomain.com
& to make ghost blog same as your current blog you need to have a custom theme developed & for content check with your current provider if they have an option to export the blog contents in json format.
The answer can’t be quick as there are many question altogether :-p
SEO, it won’t be impacted if the transition strategy is well done.
Migration: I don’t know if Squarespace offers a solid export fonction ?? If not I would simply copy paste everything manually.
The part I’m not sure is about the DNS record for Domain A & B.
I’m not sure this could work. Anyone?
CNAME www.teachmindset.com teachmindset9239489.squarespace.link
CNAME www.teachmindset.com/blog teachmindset.someprovider.link
Could there be an issue where squarespace override the /blog url ??
Else using blog.teachmindset.com is a good idea as well with a 301 redirect.
Thanks for response, pascal. I have just also discovered firepress. Hmmm… options! Tempted…
With firepress - If made a long form landing page as static home page and just had blog on ghost I can have top level contact forms etc - unless with firepress I could have 2-3 static pages? And I could transfer domain from Squarespace? There’s very little to my site…a more magazine blog would allow me to transcend education, wellbeing and coaching / business worlds - all of which I service!
If your up for challenge of helping me pull this off! Maybe with a little ghost developer help too…
Or I just host blog on ghost / firepress… and have best of both!
Yes, you can have static page manage by your Ghost theme. This means custom work, but it’s possible.
