How does ghost configure nginx in a droplet? Can I add other websites?
Quick question.
I’ve just started using my first instance of Ghost on a Digital Ocean droplet. I used the automatic installer, but I’m having a small issue. I’d like to install LimeSurvey on the same server, so that visitors can fill out a short survey about the content on my website. I’m familiar with configuring nginx (I already have two dozen domains hosted on two cloud servers I built from scratch) but it’s not obvious how ghost is using nginx – I don’t see anything in the nginx.conf file that points to /var/www/ghost, so I’m apprehensive about changing the configuration file, in case the configuration is actually somewhere else.
Thanks!
Hey :wave:
The config file is located in sites-enabled/{domain}-ssl.conf
