I have a digitalocean account and Im trying to install ghost.
domain http://dittmaraz.life .
admin http://dittmaraz.life/ghost/
How do I tell nginx to serve the ghost installation instead of that default ‘welcome to nginx’ page?
config.production.json
“url”: “http://dittmaraz.life ”,
“server”: {
“port”: 2369,
“host”: “127.0.0.1”
“database”: {
“client”: “mysql”,
“connection”: {
“host”: “localhost”,
“user”: “ghost-841”,
“password”: “eHx5S)QK41(&@0o -/^8H”,
“database”: “ghost_prod”
“mail”: {
“transport”: “Direct”
“logging”: {
“transports”: [
“file”,
“stdout”
“process”: “systemd”,
“paths”: {
“contentPath”: “/var/www/ghost/content”
“bootstrap-socket”: {
“port”: 8000,
“host”: “localhost”
Need to see the nginx config as well in order to be able to help. Overall, it should point to /var/www/ghost/ (where you ran the ghost install). If you didn’t use the one click install from DO maybe you should try that.
Also, please do not post your user and password on a public forum (not ok from a security point of view).
from nginx.conf
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
The host nginx file where you define the root folder. The nginx.conf file appears ok (just scanned it though).
I would recommend to format your config properly. I makes it hard to help you at the moment.
Per example:
"url": "http://localhost:2368",
"database": {
"client": "sqlite3",
"connection": {
"filename": "content/data/ghost-dev.db"
"debug": false
"auth": {
"type": "password"
"paths": {
"contentPath": "content/"
"privacy": {
"useRpcPing": false,
"useUpdateCheck": true
"useMinFiles": false,
"printErrorStack": true,
"caching": {
"theme": {
"maxAge": 0
"admin": {
"maxAge": 0
seth
December 16, 2018, 5:33pm
6
I have a blog post about setting up a Ghost blog with Docker and Docker Compose using Nginx on a Digital Ocean droplet here:
