Hi everyone, how can footnotes be inserted in different markdown cards all be set to show at the very bottom of the post? Example:
(first markdown card)
First sentence . Second sentence .
Then inserted video.
(second markdown card)
Third sentence .
The only way I can think to do this would be to use one long MD card for the post.
There’s a solution suggested here (with code) by Corey Mahler. I should add that I’ve not tried this myself.
The lack of proper footnotes in Ghost is a significant weakness for many forms of long form writing. All of the workarounds I’ve tried are a bit kludgy.
Thanks @Cathy_Sarisky … these work well and are what I’m using.
I changed the regex to allow {{N}} instead as I compose in Obsidian (which has a Ghost plugin) and [[N]] is used for internal linking. I also added h2 and h3 elements to the first querySelectorAll as some of my headings (weirdly) have footnotes.
I still need to add image captions and make some tweaks to the CSS
Thank you for pointing out these solutions
