How to increase member note size more than 500 characters
How do I increase the maximum text character limit size from 500 characters to more for the “note” member field?
If you’re self-hosting, you could write a migration to change the db schema. If you aren’t self-hosting, you don’t. :frowning:
What type of information are you storing? Could the same thing be accomplished with labels?
I figured out a way to connect Supabase to it so its more secure. I was able to get my quiz working!
Thank you for helping!
