I saw this feature “Enter tag slugs for primary/secondary sections” under “Site design” settings.
I do not know what it does exactly and how to make the best use of it.
Any documentation that I can read or can someone explain it here?
Thank you.
Thank you.
This is specific to your theme - the home page can have a “primary” and “secondary” section with posts appearing differently (e.g. the primary section could take up more space per-post). The list of posts displayed in the primary or secondary section are determined by the settings you’re sharing - probably comma-separated.
I am using the Headline theme. Maybe I should ask this question on the themes section of the forum.
It looks like the Environment, Culture, and Sports sections are primary, and Getting Started, Sciencr, and Technology sections are secondary
Here’s the official documentation on how that feature works:
I’m kind of torn on this feature - on the one hand, I really like the idea (with Headline) that sections change depending on what’s new. On the other hand, perhaps that will confuse people. But I guess that’s why it’s optional! I’m definitely going to try it out without setting the sections and see how it goes.
