How to Migrate From MariaDB 10 to MySQL 8
This how-to will guide you through the steps to migrate from MariaDB 10 to MySQL 8.
Ghost 5+ requires MySQL 8, as it’s a breaking change, so upgrade now if you’re running MariaDB.
I use an Ubuntu 20.04 LTS server hosted on Linode. However, the guide should work equally well on other platforms.
These are the steps:
  1. Clone the server
  2. Export the database(s)
  3. Remove MariaDB
  4. Install MySQL
  5. Setup databases and users
  6. Import the database(s)
  7. Test Ghost
  8. Change DNS
  9. Final comments
1. Clone the server
To avoid downtime while making the changes, I recommend cloning the server. This is straightforward with Linode: from the Linode screen, click on the ellipsis, and select ‘Clone’.
Open an ssh session and use the following commands to list your database and database user. Note that I have removed some lines in the output.
sudo mysql -u root -p
SHOW databases;
| Database                   |
| information_schema         |
| mysql                      |
| performance_schema         |
| sys                        |
| your_database_name           |
9 rows in set (0.002 sec)
SELECT user, host, password FROM mysql.user;
| User                            | Host           | Password                                  |
| root                            | localhost      |                                           |
| your_database_user_id           | IP address     | *                                         |
| mariadb.sys                     | localhost      |                                           |
9 rows in set (0.001 sec)
quit
Now let’s export the database. But first a couple of gotchas to be mindful of: 1. Check for host IP address or localhost as this is important when dealing with the database, 2. Confirm the database name, user ID, and password from config.production.json.
mkdir ~/Databases
cd ~/Databases
mysqldump --opt -Q -u your_database_user_id -p your_database_name > ~/Databases/your_database_name.sql
ls
total 16400
1730043 drwxrwxr-x  2 user user     4096 Apr 14 14:44 ./
1441794 drwxrwxr-x 15 user user     4096 Apr 14 14:39 ../
1730046 -rw-rw-r--  1 user user  1001188 Apr 14 14:43 your_database_name.sql
exit
Copy the file(s) to the local machine for safe keeping.
mkdir ~/Databases
cd ~/Databases
scp user@IP address:/home/user/Databases/* /home/user/Databases/
your_database_name.sql        100%   10MB   4.8MB/s   00:02
3. Remove MariaDB
Uninstall MariaDB.
sudo dpkg -l | grep mariadb
ii  libmariadb3:amd64                     1:10.8.2+maria~focal               amd64        MariaDB database client library
ii  mariadb-client                        1:10.8.2+maria~focal               all          MariaDB database client (metapackage depending on the latest version)
rc  mariadb-client-10.3                   1:10.3.34-0ubuntu0.20.04.1         amd64        MariaDB database client binaries
ii  mariadb-client-10.8                   1:10.8.2+maria~focal               amd64        MariaDB database client binaries
ii  mariadb-client-core-10.8              1:10.8.2+maria~focal               amd64        MariaDB database core client binaries
ii  mariadb-common                        1:10.8.2+maria~focal               all          MariaDB common configuration files
ii  mariadb-server                        1:10.8.2+maria~focal               all          MariaDB database server (metapackage depending on the latest version)
rc  mariadb-server-10.3                   1:10.3.34-0ubuntu0.20.04.1         amd64        MariaDB database server binaries
ii  mariadb-server-10.8                   1:10.8.2+maria~focal               amd64        MariaDB database server binaries
ii  mariadb-server-core-10.8              1:10.8.2+maria~focal               amd64        MariaDB database core server files
sudo dpkg -l | grep mysql
ii  automysqlbackup                       2.6+debian.4-2                     all          daily, weekly and monthly backup for your MySQL database
ii  libdbd-mysql-perl:amd64               4.050-3                            amd64        Perl5 database interface to the MariaDB/MySQL database
ii  libmysqlclient21:amd64                8.0.28-0ubuntu0.20.04.3            amd64        MySQL database client library
ii  mysql-client                          8.0.28-0ubuntu0.20.04.3            all          MySQL database client (metapackage depending on the latest version)
ii  mysql-client-8.0                      8.0.28-0ubuntu0.20.04.3            amd64        MySQL database client binaries
ii  mysql-client-core-8.0                 8.0.28-0ubuntu0.20.04.3            amd64        MySQL database core client binaries
ii  mysql-common                          1:10.8.2+maria~focal               all          MariaDB database common files (e.g. /etc/mysql/my.cnf)
systemctl status mariadb
sudo systemctl stop mariadb
sudo apt purge mariadb-*
 [An empty response if uninstalled]
Now remove any mysql
sudo apt purge mysql-*
sudo cp -R /var/lib/automysqlbackup/ ~
Tidy up…
sudo apt autoremove
sudo apt autoclean
sudo rm /etc/apt/sources.list.d/mariadb.list
4. Install MySQL
sudo apt update
sudo apt install mysql-server
sudo systemctl start mysql.service
sudo mysql_secure_installation
Type n for password validation, and enter your password for root. Then y for all other prompts.
Now let’s create the database user(s) and import database(s).
sudo mysql
create database your_database_name;
create user 'your_database_user_id'@'localhost' identified by 'password';
grant all privileges on your_database_name.* to 'your_database_user_id'@'localhost';
flush privileges;
quit;
mysql -u your_database_user_id -p your_database_name < /home/user/Databases/your_database_name.sql
7. Test Ghost
sudo systemctl start nginx
cd /var/www/your_website_folder
ghost start
Check that Ghost starts correctly. If there are any issues, follow the guidance from the output or run ghost doctor. Do not perform any upgrades.
For example, I needed to do one of the following on a couple of blogs:
sudo find ./ ! -path "./versions/*" -type f -exec chmod 664 {} \;
ghost update 4.39.0 --force
This reinstalled binary dependencies.
8. Change DNS
When you are satisfied that Ghost is running okay, stop Ghost (ghost stop) and change the A and AAAA records for your site. You can get the IP addresses from the Linode console.
Wait for the changes to propagate, and refresh your home page in a browser. When everything has switched, you’ll see a 502 bad gateway error.
As soon as you see this, start Ghost: ghost start.
Your site has successfully switched to MySQL.
9. Final comments.
Once the site has migrated, you can power down the original Linode and remove. Or, if you have backups associated with the Linode, or other services, e.g., analytics, repeat the above steps on your production server. Linode will only charge a few Dollars while the clone is running.
These instructions are fabulously detailed, thank you for taking the time to share this here @mjw :heart:
thanks for this. have successfully migrated to mysql. I use docker if anyone has questions on how I did it, happy to share. cheers!
Great instructions - thank you.
If you are Debian self-hosted and the database (MariaDB) is also being used by your online-shops, photo-journal publications and any other software - you will have to migrate all the other databases on the server too.
I’ve tried this a few times - in all cases, migration from MariaDB to Community MySQL8 on Debian Stable aka Bullseye (Ubuntu upstream) is bumpy. There are conflict issues with mysql-common Debian vs Community. There seem to also be differences in server authentication defaults etc.
You have to basically:
  1. Catalog ALL database USERS - e.g. echo "select concat(user,'@',host) from mysql.user" | sudo mysql
  2. Dump ALL non-infra databases and immediately stop the server - see below
  3. Remove all traces of MariaDB and old MySQL config - /etc/mysql
  4. Move the existing databases sideways - /var/lib/mysql
  5. Install a clean MySQL8
  6. Restore ALL databases
  7. Recreate ALL database USERS and grant them rights
As an assist this is a dump command for ALL non-infra databases on a server:
alldb=$(echo "show databases" | sudo mysql | grep -Ev "^(Database|mysql|performance_schema|information_schema|sys)$")
sudo mysqldump --opt --dump-date --result-file=alldb-`date +%Y%m%d-%H%M%S`.sql --routines --events --single-transaction --verbose --databases $alldb
Note that this may need tweaking for the specific version of your original database.
You should sanity check the .sql file e.g.
sudo du -sh /var/lib/mysql/
804M    /var/lib/mysql
ls -lh alldb-20220625-120156.sql
-rw-r--r-- 1 root root 154M Jun 25 12:02 alldb-20220625-120156.sql
# a reasonable size... though a lot smaller than the 804M data/indexes...
grep 'CREATE DATABASE .* IF NOT EXISTS' alldb-20220625-120156.sql
# contains all the expected databases...
view alldb-20220625-120156.sql
# content looks sane
# last line indicates that Dump completed
The MySQL Community have a package that updated apt for the install - you can start here: https://dev.mysql.com/downloads/repo/apt/ etc. etc. etc.
I just did this with docker & mariadb in 10 minutes or so…
  1. stop ghost container
  2. dump mariadb
docker exec blog_mariadb_1 mysqldump --user ghost --password=ghost ghost > db_backup.sql
  1. stopped mariadb container
  2. edited my docker-compose
  mariadb:
    image: 'mariadb:latest'
    restart: always
    volumes:
      - mariadb:/var/lib/mysql
    environment:
      - MYSQL_ROOT_PASSWORD=ghost
      - MYSQL_DATABASE=ghost
      - MYSQL_USER=ghost
      - MYSQL_PASSWORD=ghost
  ghost:
    image: 'ghost:alpine'
    restart: always
    depends_on:
      - mariadb
    volumes:
      - ./ghost:/var/lib/ghost/content
    environment:
      - database__client=mysql
      - database__connection__host=mariadb
to
  mysql:
    image: 'mysql:latest'
    restart: always
    volumes:
      - mysql:/var/lib/mysql
    environment:
      - MYSQL_USER=ghost
  ghost:
    restart: always
    depends_on:
      - mysql
    volumes:
    environment:
      - database__connection__host=mysql
  1. start only mysql container
docker-compose up -d mysql
  1. importing with docker exec didn’t work, so i copied the backup and jumped inside the mysql container
docker cp db_backup.sql  blog_mysql_1:/
docker exec -it blog_mysql_1 /bin/bash
  1. then import the backup
mysql --user ghost --password=ghost ghost < /db_backup.sql
  1. wait a little while for it to finish. the ghost database should be created automagically when you docker-compose up previously…
  2. exit the container, do a docker-compose down --remove-orphans && docker-compose up -d
  3. you are done. make sure your blog is still working
hope this helps someone
It’s a good tutorial, however, mysql 8 truncates the table, probably is the encoding. Forget it, the truncation was solved (so far) with:
Thanks a lot for the instruction. It seems in SEP-2023 that image: 'mariadb:latest' doesn’t have a mysqldump tool installed. should use mariadb-dump instead. Sourse: Docker MariaDB/Mysql dump - Stack Overflow
