How to upgrade to MySQL 8
  • What version of Ghost are you using? 5.11.0
  • What errors or information do you see in the console? You are running an unsupported database in production. Please upgrade to MySQL 8
There’s a couple of existing guides:
(ignore the nginx part)
Would these be the same steps if your upgrading from MySQL 5 to 8?
I’m currently running the ghost instance on Digital Ocean.
Ah, most people having issues are “upgrading” from MariaDB :slight_smile:
Here’s an external posts that might be useful:
I’d suggest making a backup of the entire droplet, or at least the database before trying to migrate!
Thanks for that… will take a read and most importantly a snap shot :wink:
