How to remove link to Ghost
Sorry for asking this but I’ve recently found out I can have Ghost installation on glitch.me
and so I made one.
This is my first encounter with ghost and so far so good,
Everything is very user friendly.
Except for one thing - I can’t seem to find where to remove/change link to ghost.org that appears in bottom right corner of the page.
Hey :wave: you need to remove it from your theme - Assuming you’re using Casper (the default theme), you need to edit default.hbs:36
https://glitch.me that link redirecting me to https://glitch.com/ If that is correct url then i can see you already removed that.
Otherwise you should delete that from the footer. Usually most of the premium themes used /partials/footer.hbs file for the custom footer design.
Sometime you may find that in default.hbs too as @vikaspotluri123 already mentioned that.
If you need any help regarding theme installation or customization, feel free send message to me.
Thanks
