I’ve just clicked Save Snippet on an image. I’d like to remove this snippet. How can I do it? I looked everywhere but it’s not mentioned at all where can I edit/remove snippets. Docs search cannot find anything, dashboard search cannot either.
Hey there - You can hit / and then scroll down the list to the snippet. When you hover over the one you’d like to remove, you should see a little trash can pop up:
Thanks, it worked perfectly.
