I am developing a theme and have a default.hbs file. I don’t want to render it in all my templates for example in the home.hbs template. but If I don’t include it, nothing shows up all the code in the home.hbs is not showing.
- What’s your URL?
Its a local development so its http://localhost:2368
- What version of Ghost are you using?
I am using the latest version
And
Through ghost-cli with ghost install local -
Node.js version is 18.12.1 -
None, I just need help with the question on the topic -
None
