How to style login / subscribe modals?
How do I theme these modals?
The login modal in particular.
Given my blog will be invite only I dont want the register link there.
I can’t find it in any themes. I tried atilla, and casper.
You can set a site to be invite-only under Settings → Membership
yes, I already set it to be private. I wanted to know how to theme those popups.
I’d also like to know this. Yes, you can create a whole new registration process yourself, but I think it would be great to just allow the CSS customization of the modal.
Are you saying, “CSS customization of the modal” is currently not possible at all?
I mean, it would have to be a thing right? :smiley:
It is possible, but it is a little more complicated.
I described the process here:
You can check the effect on my site (I translated modal to display it in Polish and changed it a little):
https://javowiec.pl/
I saw you added the FAQ link there and something else I don’t quite understand, since I can’t speak polish(im assuming, or russian).
I’ll take a look at the post. Thanks so far!
thanks for sharing! it’s very helpful
