Http links in mail with mailgun not working
I am having some difficulties with the Mailgun setup. Not sure what I am doing wrong.
The standard e-mails (test via labs, signin, signup, etc.) work perfectly fine. They all send a Web Hosting, Domain Name Registration - MyDomain.com
The e-mail on the publishing of articles (I assume these are the ones that use the Mailgun API) don’t work very well. I do get an e-mail correctly (not even in spam but in my inbox) but the links are http
for instance, when I click ‘VIEW ONLINE’ link (http://email.mg.mydomain.com/c/xxx) my browser gives an error:
Secure Connection Failed
An error occurred during a connection to email.mg.vetisvet.com. Cannot communicate securely with peer: no common encryption algorithm(s).
Error code: SSL_ERROR_NO_CYPHER_OVERLAP
I really have no idea how I could fix this. If somebody could point me in the right direction, that would be really nice
Cheers,
Assuming you’re using mailgun, you’re running into this because their link tracking defaults to http. You can either disable their link tracking, or see if enabling https tracking works:
Ah! I was indeed using Mailgun and Tracking Links were enabled. I disabled it as the https tracking links seem quite difficult to setup. The links are now https
Thanks!
Even if you have a wildcard cert, it may not work if you have three periods like that. E.g. blah.vetisvet.com might work, but blah.blah.vetisvet.com won’t w/ a bad cert error! Saw that today here.
