Import from wordpress as blocks
I am trying to import my blog content from wordpress, however after importing, the entire post is imported as a single HTML card.
Most of my posts consist of a combination of paragraphs and images, nothing too complex. Is there anyway to I can automatically convert an html card to paragraph / image cards? Either from within the ghost editor, or is there something I can do to the import json file to make it aware of the blocks?
I am using ghost 5
This works perfectly, thank you!
Also, now that I have been working with the ghost editor a bit more, it is SOOO much easier to use than the blogger editor. I’m on cloud 9 right now.
