Imported scheduled posts being published but not sent as a newsletter
  • I imported >100 posts using JSON using universal import feature of Ghost. These posts are all scheduled to be published in a sequence in the future. They do get published automatically, but no email newsletter are being sent.
  • When looking at the JSON for these posts, the newsletter_id is NULL. If I unscheduled posts manually, put them in drafts and then schedule publish them manually, the newsletter gets sent and the newsletter_id is correct.
How can I resolve this? I have tried setting the newsletter_id using the API but this doesn’t work. I don’t really want to manually unschedule >100 posts and then re-schedule them manually.
This may be helpful? How to use the Ghost API to schedule an email-only newsletter
Amazing - thanks. Putting all posts from “Scheduled” to “Draft” and then back again with the correct newsletter_id slug has solved it!
