Tell me, how can I make a instant view in the Casper theme, which is very often used in telegrams?
I’m not sure I understand what you’re asking.
Can you elaborate a bit more?
The preview that’s generated in Telegram should already happen automatically for any Ghost site and won’t depend (for the most part) on your theme.
Unfortunately, this does not work in all themes. Here’s an example, I’m posting 2 threads on gho, one works with quick article preview, the other doesn’t.
I checked this out, and Instant View seems to be a Telegram thing. You’ll need to set up a template through them: https://instantview.telegram.org/
