I run https://marketingjunto.com. Is there a way to ditch the “Subscribe” button until scroll? At least on mobile
I like your theme!
Because of how Portal works, it’s not really possible to add the kind of scroll animation you mentioned.
As an alternative, you could turn off the Portal button (under the Customize Portal settings) and implement your own button with scroll animations.
Thanks so much! I appreciate your help!
