According to two Youtube tutorials that seem to be working according to user comments I should be able to see a setup site after deploying the droplet when visiting the IP. Unfortunately even after multiple destryoed droplets and retries I keep getting a 403 when trying to visit a fresh installation. Any advice?
→ Did that for some droplets, destroyed others without doing it. Didn’t seem to make a difference.
What’s your URL? www.michaelkueng.com - (likely won’t help because I keep recreating droplets to try to get it to work and TTL min is 60min) after having run the Ghost update through the terminal the domain and IP alike revert to a 404 instead of the initial 403. Will redo the whole thing once again to reproduce the 403 issue.
What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
Dialed in through the terminal as root user to do that multiple times, skipped it for other droplets, never seemed to make a difference.
1-click installation through Digitalocean marketplace -
node.js 18.17.1
database - never made it past the ghost update in the terminal to follow through with the initially proposed mysql installation
OS - Microsoft Windows 10 Pro, 10.0.19045 Build 19045
Browser - Google Chrome Version 120.0.6099.130 (Official Build) (64-bit)
Downloading and installing Ghost v5.75.2
A ProcessError occurred.
warning ghost@5.75.2: The engine “cli” appears to be invalid.
warning Resolution field “@elastic/elasticsearch@8.5.0” is incompatible with requested version “@elastic/elasticsearch@8.10.0”
warning Resolution field “moment@2.24.0” is incompatible with requested version “moment@^2.29.1”
warning Resolution field “moment@2.24.0” is incompatible with requested version “moment@2.29.1”
warning Resolution field “moment@2.24.0” is incompatible with requested version “moment@^2.27.0”
warning Resolution field “moment-timezone@0.5.23” is incompatible with requested version “moment-timezone@^0.5.31”
warning Resolution field “moment@2.24.0” is incompatible with requested version “moment@2.29.4”
warning Resolution field “moment-timezone@0.5.23” is incompatible with requested version “moment-timezone@0.5.34”
warning Resolution field “moment@2.24.0” is incompatible with requested version “moment@2.29.3”
warning Resolution field “@tryghost/errors@1.2.26” is incompatible with requested version “@tryghost/errors@^1.2.27”
warning Resolution field “moment-timezone@0.5.23” is incompatible with requested version “moment-timezone@^0.5.33”
warning Resolution field “moment@2.24.0” is incompatible with requested version “moment@2.27.0”
warning Resolution field “@tryghost/errors@1.2.26” is incompatible with requested version “@tryghost/errors@1.2.25”
warning Resolution field “@tryghost/logging@2.4.8” is incompatible with requested version “@tryghost/logging@2.4.5”
warning “@tryghost/kg-default-nodes > @lexical/rich-text@0.12.2” has unmet peer dependency “@lexical/selection@0.12.2”.
warning “@tryghost/kg-default-nodes > @lexical/rich-text@0.12.2” has unmet peer dependency “@lexical/clipboard@0.12.2”.
warning “@tryghost/kg-default-nodes > @lexical/rich-text@0.12.2” has unmet peer dependency “@lexical/utils@0.12.2”.
warning " > bookshelf@1.2.0" has incorrect peer dependency “knex@>=0.15.0 <0.22.0”.
yarn install v1.22.19
[1/5] Validating package.json…
[2/5] Resolving packages…
[3/5] Fetching packages…
[4/5] Linking dependencies…
[5/5] Building fresh packages…
OS: Ubuntu, v22.04.3 LTS
Node Version: v18.17.1
Ghost-CLI Version: 1.25.3
Environment: production
Command: ‘ghost install --auto --db=mysql --dbhost=127.0.0.1 --dbport=3306 --dbname=ghost_production --dbuser=root --dbpass=XYZ --dir=/var/www/ghost --start’
Use the oneclick installer from the Digitalocean marketplace
