“mailto” link not working
Trying to add a mailto: hyperlink inside text in a post. The “link to local stories” popup then changes the link to whatever URL it thinks I’m trying to enter.
Wound up doing just that graf in markdown.
Anyone else seeing this?
This was fixed in the latest release. Are you still having problems?
Yes. But, I’m not sure what version my host has me on. (He controls the updates.)
I used to be able to check the version through the What’s New menu on my avatar. But, that has changed. I’ve spent about 20 minutes trying to find the new way to check version, but haven’t been able to. So, tell me the latest way to check the version, and I’ll report back. Thanks!
You can open the settings and scroll to the bottom of the navigation sidebar to reach the About screen. (I thought it should be searchable but it appears not to be - I’ll raise that as an issue)
5.8.3
Thanks for your help!
