Hello,
I have certain posts which are member-only. However, the image for the posts on the website have a lock attached to them (see attached image). Is there a way to remove that lock so it shows the image normally?
Thanks!
Piroune
Hello,
Thanks!
Piroune
It sounds like this might be a feature of your theme. Which theme are you using? Can you share a link to your website?
Hi Kym,
Thanks for your response! I was using Casper, but decide to switch to massively theme since that works better for my content at the moment.
Best,
Piroune
