I’m trying to install the gatsby-starter-ghost package which works fine on my local machine but fails when deploying to netlify.
The error-log in netlify is as follows:
6:47:37 PM: error "gatsby-source-ghost" threw an error while running the sourceNodes lifecycle:
6:47:37 PM: Cannot read property 'status' of undefined
6:47:37 PM: 105 |
6:47:37 PM: 106 | const ignoreNotFoundElseRethrow = (err) => {
6:47:37 PM: > 107 | if (err.response.status !== 404) {
6:47:37 PM: | ^
6:47:37 PM: 108 | throw err;
6:47:37 PM: 109 | }
6:47:37 PM: 110 | };
6:47:37 PM:
6:47:37 PM:
6:47:37 PM: TypeError: Cannot read property 'status' of undefined
6:47:37 PM:
6:47:37 PM: - gatsby-node.js:107 ignoreNotFoundElseRethrow
6:47:37 PM: [repo]/[gatsby-source-ghost]/gatsby-node.js:107:26
6:47:37 PM:
6:47:37 PM: - task_queues.js:97 processTicksAndRejections
6:47:37 PM: internal/process/task_queues.js:97:5
6:47:37 PM:
6:47:37 PM:
6:47:37 PM: not finished source and transform nodes - 0.199s
6:47:37 PM:
6:47:37 PM: ┌─────────────────────────────┐
6:47:37 PM: │ "build.command" failed │
6:47:37 PM: └─────────────────────────────┘
6:47:37 PM:
6:47:37 PM: Error message
6:47:37 PM: Command failed with exit code 1: NODE_ENV=production gatsby build
6:47:37 PM:
6:47:37 PM: Error location
6:47:37 PM: In build.command from netlify.toml:
6:47:37 PM: NODE_ENV=production gatsby build
6:47:37 PM:
6:47:37 PM: Resolved config
6:47:37 PM: build:
6:47:37 PM: command: NODE_ENV=production gatsby build
6:47:37 PM: commandOrigin: config
6:47:37 PM: publish: /opt/build/repo/public
6:47:37 PM: Caching artifacts
6:47:37 PM: Started saving node modules
6:47:37 PM: Finished saving node modules
6:47:37 PM: Started saving build plugins
6:47:37 PM: Finished saving build plugins
6:47:37 PM: Started saving pip cache
6:47:37 PM: Finished saving pip cache
6:47:37 PM: Started saving emacs cask dependencies
6:47:37 PM: Finished saving emacs cask dependencies
6:47:37 PM: Started saving maven dependencies
6:47:37 PM: Finished saving maven dependencies
6:47:37 PM: Started saving boot dependencies
6:47:37 PM: Finished saving boot dependencies
6:47:37 PM: Started saving go dependencies
6:47:37 PM: Finished saving go dependencies
6:47:41 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
6:47:41 PM: Failing build: Failed to build site
6:47:41 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2
6:47:41 PM: Finished processing build request in 1m6.723797109s
Netlify.toml:
[build]
command = "NODE_ENV=production gatsby build"
publish = "public/"
[template]
incoming-hooks = ["Ghost"]
ghost.json:
"development": {
"apiUrl": "http://localhost:2371",
"contentApiKey": "34f7e3a488b67c1871a036c666"
"production": {
utils/siteConfig.js:
module.exports = {
siteUrl: `http://0815pascal.netlify.app`, // Site domain. Do not include a trailing slash!
postsPerPage: 12, // Number of posts shown on paginated pages (changes this requires sometimes to delete the cache)
siteTitleMeta: `Ghost Gatsby Starter`, // This allows an alternative site title for meta data for pages.
siteDescriptionMeta: `A starter template to build amazing static websites with Ghost and Gatsby`, // This allows an alternative site description for meta data for pages.
shareImageWidth: 1000, // Change to the width of your default share image
shareImageHeight: 523, // Change to the height of your default share image
shortTitle: `Ghost`, // Used for App manifest e.g. Mobile Home Screen
siteIcon: `favicon.png`, // Logo in /static dir used for SEO, RSS, and App manifest
backgroundColor: `#e9e9e9`, // Used for Offline Manifest
themeColor: `#15171A`, // Used for Offline Manifest
I’m running:
node v12.8.3
Ghost-CLI v.1.14.1
npm v6.14.8
Gatsby CLI v.2.12.106
Gatsby v.2.24.67
I also tried it by deleting yarn.lock since this has worked for someone but to no avail.
