I have two Ghost Pro sites and I am condensing them into 1, is there a way to export ONLY posts from one of them to import?
I can see you can export but I do not want to overwrite the settings from the site I’m going to use as it’s already up and running.
Thanks,
I’m not sure about that, but if you’re comfortable editing JSON, you can remove the settings from the export.
Hey Ghost team, if you’re listening, it would be /really/ nice to have some more fine-grained import or export tools. (I’m not picky which - I’m happy to say “just give me posts” on the import or “just write out posts” on the export.
Yeah I can do that just didn’t know if the import would accept just the posts.
Will give it a go today and test my luck.
Would be a good feature to add!
