OpenVZ or KVM on VPS?
Hey gang.
Looking to move to a ghost from Wordpress for my main blog. I will be self hosting on a VPS. From what I can tell in the documentation, there is no need for a KVM VPS to run ghost? Is that correct?
I know with Discourse, a KVM VPS is needed due to the Docker requirements.
Cheers
Hey there :wave:
It shouldn’t really matter, as long as you can get MySQL, Node and NGINX installed, you should be fine. I don’t think any of the components are affected by the underlying virtualization tech is involved :)
If needed, here’s the step-by-step guide to install Ghost:
Thanks - I will get a cheapie OVZ then. I have installed Ghost a bunch of times, so it should be straight forward assuming no virtualization checks in the installer.
Cheers,
