Hello
is there anyway to password protect posts?
i want to show my clients their images in order to confirm the work, I need to post their image & get them a link with a password to access it. is it possible inside ghost?
Hey ![]()
And here:
Thanks.
I saw them before post here, I want to only password protect specific posts not the entire site.
Hmmmm… nothing native in Ghost because there would not be a widespread utility for such functionality, but if you’re good with code, you can roll something like this.
With Ghost Members, you can authorize the viewing of a post based on affiliation (e.g., member, paid, free, etc.). I don’t see why that can’t be reversed engineered to use the password protect functionality instead. It’ll be a bit of imagination, time, and programming.
If you need something more expedient, you can simply use the aforementioned Ghost Members feature, like:
- Implement a Ghost Members “free” tier.
- Create a post w/ images and designate it as member only using
‘post access levels’. - Have the client sign up via email to view that particular post.
Success! That may be the simplest way of doing it.
Thanks for suggestion, I should think about this.
As I currently run my graphic design / photography studio site on Ghost, I prefer to have this function also in my own site & don’t use 3rd party systems.
I would also like to see this built in to Ghost, not as a suscriber feature, but ability to password protect a post.
Kind of got something working: I used basic server side authentication protect a collection slug. In a nutshell, I’m on DigitalOcean and running Nginx, so I set up a user/password combo and added it to the config file for my Ghost installation in /etc/nginx/sites-enabled/. I also created a new collection so that I easily protect any new post by adding it that tag. I wrote up more detailed steps here: Password protecting only some pages on Ghost
I originally had set up what Titus was suggesting with a free tier. I set subscription access to “only people I invite” so I wasn’t worried about people signing up and getting access to the protected content. An alternative would be to create a paid tier for a ridiculous prices (e.g. $999,999/mo) and comp free accounts to people who you want to give access. That said, it still uses a magic link to sign in, and in some cases it’s easier to just have a simple password (e.g. to password protect your portfolio)
This would be awesome feature. One quick solution which came to my mind is to make page instead of post. You can use some unguessable custom url like:
https://myGhostDomain.com/this-is-super-secret-slug-nobody-can-guess
To avoid indexing of such site from google bot you should inject this code into head:
<meta name="robots" content="noindex,nofollow" />
Such page link will be exploreable only in ghost sitemap.xml. It might be enough for your usecase? Just idea.
If you’re looking for an easy way with a GUI interface to control access outside that of the membership functionality which I would suggest you use, perhaps [Cloudflare’s Access product] (https://www.cloudflare.com/en-gb/products/zero-trust/access/) might suit?
If you want to “password protect” the post so that people with specific emails can receive One Time Pins to enter, you could setup a Lambda / Zapier function to call Cloudflare’s API to add certain labelled member email addresses to Cloudflare’s access list. Then all people have to do it enter their email, receive a OTP through their email and they’re in for a session period (also customisable)
Here’s a screenshot of the “application domain path setup” just to show you how easy it is to setup specific website paths or wildcard paths to protect. There is a generous free tier that they offer!
Cheers,
Alex.
Claude Code helped me password-protect part of a page. It seemed cleaner than deploying Cloudflare Worker.
