Permission denied when updating: Source theme linking
Getting an error when updating self-hosted, with permission linking problem to new Source theme. Error as follows. I’m guessing it’s because I don’t actually have that theme?
:heavy_multiplication_x: Linking built-in themes
An error occurred.
Message: ‘EACCES: permission denied, symlink ‘/srv/www/sitename/current/content/themes/source’ → ‘/srv/www/sitename/content/themes/source’’
I recommend checking what the owners and permissions are on those two paths mentioned.
You can use ls -l filename to check that.
The second is a symlnked folder, and it obviously doesn’t exist given the symlink permission denied error. The first folder has the same permissions as the rest of the themes.
I’m seeing the exact same issue.
Is there a problem with the installer script?
Huh strange, I can’t reproduce this when doing a v5.66.1 → v5.67.0 update :thinking:
Can you give the output of the following commands?
whoami
ls -la /<ghostdir>/content/themes
ls -la /<ghostdir>/current/content/themes/
Hey there,
I came across the same error while updating my Ghost instance from v5.65.0 to v6.67.0 via Ghost CLI.
After I got the “EACCES: permission denied, symlink” error, I had to create the symlink manually to fix the issue, I ran the following commands:
sudo ln -s /var/www/site_name/current/content/themes/source /var/www/site_name/content/themes/source
cd /var/www/site_name/ && sudo chown -R ghost:ghost ./content
ghost start
Update: I think I’ve found the issue. Will come back when I have more
Ghost-CLI v1.25.2 should now contain the fix for this: Release v1.25.2 · TryGhost/Ghost-CLI · GitHub
You can either update to that, and then rollback and update Ghost again, or use the workaround that @JuanDelgadillo posted right above (I’d probably do this one)
Thanks for the report :slightly_smiling_face:
Yep, I realised that updating ghost-cli stops the error from happening :+1:
npm install -g ghost-cli@latest
I got this error and my Ghost version is 5.66
The theme “Source” was installed successfully but we detected some errors.
Errors
Highly recommended to fix, functionality could be restricted
package.json property "config.custom" contains too many settings
](Ghost Admin)Remove key from "config.custom" in your package.json to have less than or exactly 15 settings.
Check the package.json documentation for further information.
Affected files:
  • package.json
Solved with the update.
