Hello team, just installed Ghost on DO - finally ![]()
but, subscribe button is not showing up in the bottom right.
@andrii it’s showing up ok for me. Did you fix the problem? If it’s still not working for you try in a different browser or in incognito mode or similar to rule out an extension from interfering. If you open your browser’s inspector then there may be relevant errors shown in the console tab.
Yes it is fixed! Solution - I restarted ghost.
