Post by api failure
POST JSON:
	"posts": [
            "title": "Hello, world",
            "slug": "Hello, world",
            "markdown": "Hello, world",
            "status": "published"
RETURN JSON:
    "posts": [
            "id": "5b9dde5c701233235cbf1196",
            "uuid": "3df6db74-2cca-4627-bdb5-07931ab356d0",
            "slug": "hello-world-2",
            "html": "<p></p>",
            "comment_id": "5b9dde5c701233235cbf1196",
            "feature_image": null,
            "featured": false,
            "page": false,
            "status": "published",
            "locale": null,
            "visibility": "public",
            "meta_title": null,
            "meta_description": null,
            "created_at": "2018-09-16T04:38:52.000Z",
            "created_by": "1",
            "updated_at": "2018-09-16T04:38:52.000Z",
            "updated_by": "1",
            "published_at": "2018-09-16T04:38:52.000Z",
            "published_by": "1",
            "custom_excerpt": null,
            "codeinjection_head": null,
            "codeinjection_foot": null,
            "og_image": null,
            "og_title": null,
            "og_description": null,
            "twitter_image": null,
            "twitter_title": null,
            "twitter_description": null,
            "custom_template": null,
            "author": "1",
            "primary_author": null,
            "url": "/hello-world-2/",
            "primary_tag": null
html field is always <p></p>
Could you tell me why?
Thanks!
The current v0.1API requires a mobiledoc field from which to generate the html and plaintext content from. You’re using a private API that is not documented or designed for external use so there’s not much information available for what you’re trying to do.
If you can wait I would suggest waiting for the new v2 API and authentication mechanisms to land:
If you can’t wait then you should examine the network requests made by the admin area (it’s an SPA that uses the private API) to determine the required fields and formats.
OK, Thanks!
