Windows 10
Ghost-cli version : 1.17.3
Ghost version : 4.9.0
Node version : 14.16.0
Npm version : 7.19.1
I’m trying to install Ghost for the first time locally. According to the supported versions , Node 14.x seems to be recommended.
So I followed the installation steps :
npm install -g ghost-cli@latest
ghost install local --verbose
When an the error occured :
Am I doing someting wrong ?
Thanks
The error message tells you the issue ;) You need at least node v14.16.1 due to security patches:
As of the next Ghost release (v4.5.0), the minimum supported versions of Node.js will be changing.
Node.js v10 became end of life on April 30th 2021, therefore it will no longer be supported.
Node v12 and Node v14 have both had numerous security fixes and so we will take this opportunity to also push support to the latest, secure versions.
How to Upgrade
You can upgrade in advance
curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash to update your source list to Node…
The error message just tells that there is a version issue. I searched on the documentation and there is no indications on which version is compatible with which version of node.
Anyway, thanks for your reply !
