I have a problem when I want to upload the theme. Here are the details:
Likewise, when I’m writing a post, there’s always a notification like this:
Check your logs, and file and folder permissions using ghost doctor.
This is the output from ghost doctor. Please stop Ghost and re-run, and also check the logs, which are located in the Ghost folder.
I am sorry. Is this what you mean?
[ghost-anwarsafii (14)] [beritawa@champagne ghost-anwarsafii]$ ghost stop
https://careers.ghost.org
✔ Stopping Ghost: ghost-local
[ghost-anwarsafii (14)] [beritawa@champagne ghost-anwarsafii]$ ghost run
The `ghost run` command is used by the configured Ghost process manager and for debugging. If you're not running this to debug something, you should run `ghost start` instead.
[2023-03-17 10:24:23] INFO Ghost is running in development...
[2023-03-17 10:24:23] INFO Listening on: 127.0.0.1:2368
[2023-03-17 10:24:23] INFO Url configured as: https://anwarsafii.dev/
[2023-03-17 10:24:23] INFO Ctrl+C to shut down
[2023-03-17 10:24:23] INFO Ghost server started in 4.655s
[2023-03-17 10:24:24] INFO Database is in a ready state.
[2023-03-17 10:24:24] INFO Ghost database ready in 5.692s
[2023-03-17 10:24:34] INFO Ghost URL Service Ready in 15.512s
[2023-03-17 10:24:34] INFO Adding offloaded job to the queue
[2023-03-17 10:24:34] INFO Scheduling job clean-expired-comped at 11 45 3 * * *. Next run on: Sat Mar 18 2023 03:45:11 GMT+0000 (Greenwich Mean Time)
[2023-03-17 10:24:34] INFO Scheduling job clean-tokens at 20 9 13 * * *. Next run on: Fri Mar 17 2023 13:09:20 GMT+0000 (Greenwich Mean Time)
[2023-03-17 10:24:34] INFO Ghost booted in 15.674s
[2023-03-17 10:24:34] INFO Scheduling job update-check at 26 2 8 * * *. Next run on: Sat Mar 18 2023 08:02:26 GMT+0000 (Greenwich Mean Time)
[2023-03-17 10:24:34] INFO Running milestone emails job on Sat Mar 18 2023 10:24:34 GMT+0000 (Greenwich MeanTime)
The logs are located in the content folder.
Please run ghost doctor with Ghost stopped.
Incidentally, you’re using development mode. Is this intentional?
for development mode, i just followed a tutorial. Do I have to change it to production mode?
[ghost-anwarsafii (14)] [beritawa@champagne ghost-anwarsafii]$ cd content
[ghost-anwarsafii (14)] [beritawa@champagne content]$ ghost doctor
Working directory is not a recognisable Ghost installation.
Run `ghost doctor` again within a folder where Ghost was installed with Ghost-CLI.
[ghost-anwarsafii (14)] [beritawa@champagne content]$ ghost stop
Ghost is already stopped! For more information, run:
ghost ls
[ghost-anwarsafii (14)] [beritawa@champagne content]$ ghost ls
│ Name │ Location │ Version │ Status │ URL │ Port │ Process Manager │
│ ghost-local │ ~/ghost-anwarsafii │ 5.38.0 │ stopped │ n/a │ n/a │ n/a │
[ghost-anwarsafii (14)] [beritawa@champagne content]$ cd ..
[ghost-anwarsafii (14)] [beritawa@champagne ghost-anwarsafii]$ ghost doctor
✔ Checking system Node.js version - found v14.20.1
ℹ Ensuring user is not logged in as ghost user [skipped]
ℹ Checking if logged in user is directory owner [skipped]
✔ Validating config
✔ Checking free space
Only you can answer this. I don’t know the purpose of the installation.
You need to run ghost doctor in the folder Ghost is installed.
✖ Validating config
One or more errors occurred.
1) Validating config
Error detected in the development configuration.
Message: Port '2368' is in use.
Configuration Key(s): server.port
Current Value(s): 2368
Help: Run `ghost config <key> <new value>` for each key to fix the issue.
OS: unknown, vunknown
Node Version: v14.20.1
Ghost Version: 5.38.0
Ghost-CLI Version: 1.24.0
Environment: development
Command: 'ghost doctor'
Well, there you have it! Your configuration is broken. Please share config.development.json, and if you’re using Nginx, the config for that, too.
still not working. Even after the config checklist
✔ Checking system Node.js version - found v14.21.2
✔ Validating config
Please provide the information I requested. Thanks.
Thanks for all the replies. The solution is resolved by reinstalling ghost.
