Problem with changing the theme
I have installed ghost on DigitaOcean and by default the theme is Casper. However, I want to use the “LIEBLING” theme. I have successfully downloaded the theme and I uploaded the zip file on ghost admin. Although after activating the theme, the entire page looks like an html page. How can I successfully use the LIEBLING theme?
Hi there! Did you make sure to download the theme from the releases tab on the GitHub repo?
Thank you very much. I am able to do it. Thanks for your support.
Hi, I’m also having problems. For me, when I upload the theme from the releases tab it says “the file type you uploaded is not supported”?
