Problem with "ghost restart"
Ghost-CLI version: 1.30.1
Ghost version: 6.55.0
Self-hosting
node v22.23.2
I have installed ghost successfully on Ubuntu 26.04 LTS.
Everything worked fine.
When try to restart ghost, usually, you’re prompted for the sudo password
ghost restart
+ sudo systemctl is-active ghost_localhost
? Sudo Password [input is masked]
But in this installation
ghost restart`
The script hangs here, because it doesn’t automatically prompt for the sudo password!
It only works if you enter it manually:
sudo systemctl restart ghost_localhost
[sudo: authenticate] Password:
and then
ghost restart
Can this be a bug of Ghost-Cli v1.30.1?
Should I give sudo visudo -f /etc/sudoers.d/ghost-restart a try?
Thanks for help.
Found the solution with the help of AI Claude:
The new server with Ubuntu 26.04 LTS use another “sudo”!
You have to choose /usr/bin/sudo.ws (classic sudo) = Number 1
update-alternatives --config sudo
 Selection    Path                     Priority   Status
* 0            /usr/lib/cargo/bin/sudo   50        auto mode
  1            /usr/bin/sudo.ws          40        manual mode
  2            /usr/lib/cargo/bin/sudo   50        manual mode
Press <enter> to keep the current choice[*], or type selection number: 1
Now it works as expected.
ghost restart
https://careers.ghost.org
✔ Sudo Password
+ sudo systemctl restart ghost_localhost
✔ Restarting Ghost
Maybe this is helpfull for others.
Keep in mind, the /usr/bin/sudo.ws (classic sudo) is vulnerable:
Heap Buffer Overflow in Sudo (CVE-2021-3156) Enables Privilege Escalation on Linux OS
Maybe you can update Ghost-Cli in future versions!
A fix for this has been shipped in Ghost-CLI 1.31.0 :+1:
