Hello,
I have injected the following code which will add the LinkedIn icon to my navigation and make the logo on the top bar bigger:
.nav .nav-linkedin a { font-size: 0 !important; }.nav .nav-linkedin a::before {
font-family: "Font Awesome 6 Brands";
display: inline-block;
font-size: 20px;
font-style: normal;
font-weight: normal;
font-variant: normal;
text-rendering: auto;
-webkit-font-smoothing: antialiased;
.nav .nav-linkedin a::before {content: "\f08c"}
.gh-navigation-logo img {
max-height: 65px;
It all worked fine with my setup, showing the Publication cover in the Landing layout for the Homepage (Source theme).
I then tried to change the header font colour displayed on top of the publication cover image, which is currently white. I added and removed pieces of code from the code injection, but it didn’t work (I am stating this only to describe what I did, the header font colour is a separate issue).
Long story short, now the publication cover is not showing in the landing layout of the homepage anymore.
Please help! Thanks a lot!
Alex
