I’m using Ghost 3.2.0 and I’m wondering how to reset/revoke/re-issue the Admin API Key for Zapier integration? WIth custom integrations I can just delete them, but with Zapier there doesn’t seem to be a way to re-generate the key if it becomes compromised.
I found the key in the database and could simply change it there, but I’m not sure what the implications of that would be (it seems like a bad idea to just change random data in the database versus using the front end). Does anyone know a proper way to change the key?
