Hey,
I have a ghost Blog + website and I just updated my website to the latest ghost version. I use a custom slightly modified version of the casper theme.
I noticed that on my existing pages i can no longer change any links that refer to my domain from their http version to their https version or from absolute url to /path/to/asset (Other domains work fine and I can freely change them)
Furthermore on the design page, I have the same issue. All links are http, and I can’t change them to https or to /path/to/page UNLESS, the domain is not my website.
By “I can’t change” I mean, I can click save/publish but after I leave the page (or the field) it reverts to the previous value.
It’s not a permission issue, as I can modify the web pages, add text, create new pages, etc, just not links to my own website. Any ideas?
EDIT: Solution. Set the url to https in the ghost config? (New option when migrating from 2.X to 3.X?)
ghost config set url https://webfives.com
From: Ghost blog returning images via http instead of https - #2 by badrihippo
Cheers,
Nick
Hi @XapaJIaMnu,
welcome to ghost.
Was SSL properly configured during ghost setup?
You could have a look in your terminal and run $ ghost setup ssl nginx
Also running $ ghost doctor could give more info if something not right with ghost.
Hey @daniel1,
Thank you for your reply. Ghost doctor reports everything is good:
$ ghost doctor
✔ Checking logged in user
✔ Checking operating system compatibility
+ sudo systemctl is-active ghost
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
I think SSL is configured properly, but I have no idea how to tell?
Nginx configuration already found for this url. Skipping Nginx setup.
ℹ Setting up Nginx [skipped]
Nginx setup task was skipped, skipping SSL setup
ℹ Setting up SSL [skipped]
Also
$ curl http://my-website.com
<html>
<head><title>301 Moved Permanently</title></head>
<body bgcolor="white">
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx/1.14.0 (Ubuntu)</center>
</body>
</html>
And redirects to the https version.
EDIT:
I have both website-ssl.conf and website.conf:
They are:
if ($host = www.mywebsite.com) {
} # managed by Certbot
if ($host = mywebsite.com) {
listen 80;
listen [::]:80 ipv6only=on;
server_name website.com www.website.com;
root /var/www/ghost/system/nginx-root;
location / {
proxy_pass http://127.0.0.1:2369;
location /files {
autoindex off;
alias /var/www/files;
location ~ /.well-known {
allow all;
client_max_body_size 50m;
AND the ssl-version:
server {
listen 443 ssl http2;
listen [::]:443 ssl http2 ipv6only=on;
server_name mywebsite.com www.mywebsite.com;
ssl_certificate /etc/letsencrypt/live/mywebsite.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/mywebsite.com/privkey.pem; # managed by Certbot
include /var/www/ghost/system/files/ssl-params.conf;
location /files {
autoindex off;
location / {
allow all;
Cheers,
Nick
